I'm posting this here for reference. I bought a license plate relocation kit that will move my license plate from its current position to centered on the back in front of my spare tire. When I bought the kit I had no idea it would become such a pain to wire. There are no step-by-step instructions and the posts that I could find were all JK wiring instructions. I swore that when I figured it out I would post it here for reference so that nobody has to waste as much time on this as I did. The kit I that I bought is made by Warrior Products and it didn't come with wiring instructions, their support supplied me with zero help as well so that was awesome!
The wiring is fairly simple. I'm attaching a diagram for reference. Basically you just cut off your 3rd Light and there are 2 wires:
Black wire = Power
White wire = Ground
SIGNAL LIGHT ON KIT:
You will connect both wires from the signal light on your kit to the black and white wires that were connected to the old 3rd light you removed.
LICENSE PLATE LIGHT:
This part is a bit tricky. There are two wires that run off of your license plate light. One is a ground and one is power.You will run your ground wire to the ground wire you pulled off of your old 3rd light. To run the power wire you have to tap into either your right or left taillight, both sides have a black wire with a yellow stripe, that wire is your running light. This is the part that drove me crazy, MAKE SURE YOU HAVE YOUR HEADLIGHTS ON when you test this wire. Remember, your license plate light is only going to run when your taillights are ON. I almost lost my mind thinking that there was no power to that wire until it dawned on me that the headlights need to be on, so don’t make that mistake. After that you’re done. It’s pretty easy but I couldn’t find any wiring for a TJ so I wanted to post it.
Black wire = Power
White wire = Ground
