Learn me some Pre-Cat delete...
31K views 15 replies 10 participants last post by  ylwseal
Didn't find anything in my search.
Patient: 05 TJ Sport with dual pre-cats immediately below the header.
Can pre-cats be deleted without upsetting the ECU?
Does anyone sell an exhaust system that is a header back that deletes the pre-cats?
Inquiring felines wanna know
I have gutted my pre cats due to some previous problems, it didn't throw codes at first but now I'm getting two P0421 and P0431 (bank 1 and 2 warm up catylist). I am also trying to figure out options to bypass this, or new exhaust system. I haven't found a way for it to pass without them. Been doing some research but no luck *Subscribed*
Ive thought of the idea so I looked into it a bit and heard mixed stuff but mostly heard if you pull the sensor out of the exhaust pipe a little bit using a spark plug non fouler it doesnt read as well wich shouldnt code. I have yet to hear of any performance gains from doing this wich is why I have not done it. Also I have heard of dummy sensors that are sold, if you do enough research im sure you can find what tthe neaded resistance of the sensor is and make your own.
I have a 2001 TJ w/ pre-cats, w/o down stream cat, my buddie has 2000 TJ with straight head pipe, no pre-cats, OEM head pipe. You could order older head pipe and adapt O2 sensors. (Im sure you could find a work around for the O2 sensors all you need is the right resistors to fool sensor) 2000's have O2 sensor at downstream cat. Or just weld bungs into pipe screw in sensors. Just my 2 cents good luck
#11 ·
Just replaced mine with an Eastern full system from RockAuto for less than 300. It's direct fit, but I left the main cat off. Originally gutted the other pre cat after throwing a code and finding the blown one. Ran it like this for a few months but still got CEL. I also used the spark plug fouler trick, but continued to throw codes. Jeep was also drinking fuel. I was getting about 8-10 mpg on a good day. Only other option I've heard of is the O2 sensor dummies. For reference, mine's an 04 Rubi. Good luck.
#13 ·
I was looking at running my own exhaust system from the headers back. I have the split header setup. I was planing on removing the pre cats and changing the main cat to a flowmaster #2000125. According to them this cat can handle up to a 5.7L motor and vehicle weight of 6K lbs. I would leave the pre o2 sensors in place and move the rear two to behind the new cat so hopefully i wont get any CEL's. Will this work and still pass and emissions test?
#14 ·
I used to work for an emissions company here in colorado and I can say this, the company knows how many cats each car has and they look for them. If you don't have them you fail. If you can do a drivethrough emissions test than its up to how good your system is, you may or may not fail. On the tests that you just drive through its all about numbers. If you have to get out of your car and let them expect it for the emissions system, it will fail.
