New Cooper SST Pro
24K views 96 replies 36 participants last post by  Yellow 09 JK
For the life of me I couldn't get them to stop pulling left. We did an alignment check and I was right to spec. We did radial pull rotations on both sides and even put on two new rears. Still pulled to the left. not to mention they suck on snow and crusty packed snow.
I'm now divorced from nitto... Thank gawd
Having 35's put on my Daughters Jeep today, will be interesting to see the difference, I have the STTs on mine.
#10 ·
I really like the looks of them! But I'm afraid they will suck in snow and on ice so a deal killer for me...which is too bad
#11 ·
They are sipped, we get some snow/ice here in Oregon, so I will know more soon, having the STT Pros put on my Daughters Jeep today.
They have excellent wet pavement performance.
#12 ·
That review was impressive.
Did not think that any vehicle would be able to climb the 'slick' portion of that 30 degree wall when wet, especially starting from a stop on the incline.
#13 ·
Here is my Daughter's JKUS with the 35" STT Pros on 20" Dropstar Rims
#14 ·
Looking forward to hearing a review on these...
#18 ·
Yes, advanced tread material, and improved tread design. And I can say that the Pro does seem to actually ride better.
#21 ·
I've had these on my JKUR since around last November. I love them. I'm running 37/12.50/17. They ride really well. They aren't very noisy. They do AMAZING on wet roads. It doesn't snow in South Texas, so I can comment on winter performance. I highly recommend them to anyone. I just wish they made them in 40's.
#25 ·
A friend has these on her JK. 33" x 15 x something. They drive really well on the road. I bit more noise than the KMs, but not distracting. Great wear too, thanks to the high silica content.
The only down side *may* be in chipping and tread cuts in sharp rocks (I notice this with the S/T Maxx).
*If* so, that's a small niggle in my mind for anyone short of a full on rock hound.
Question for those of you with the 37x17R versions:
Do you notice any "flat spotting" when sitting over night?
How did they balance out weight-wise?
Tia,
#34 ·
The 295/75R18 tire which they call an advertised 35" (actually measures at exactly 34" mounted at around 40 PSI) weighs in at 69 lbs. I weighed the tire/stock sahara wheel combo on a scale myself and tagged exactly 96 lbs. I then looked up that my wheel alone should weight 27 lbs so simple math tells me the tire is 69 lbs.
#33 ·
Thanks for the reviews. I've ordered a set of these in 295/65r20, (35.4" advertised height) as well as a tire re-grooving tool so I can add siping into the tread blocks that do not have any, for better rain, ice and snow performance. Upgrading from 275/65r20 BFG KO2's (advertised height of 34.1"), which I really like. I just wanted something a little bit taller without going too much wider. I'm a fan of skinny and tall tires.
FYI;
Using a $100 off coupon on EBAY for a pair, made 2 orders and all 4 tires came to $1100 shipped (free shipping and $100 coupon good until 3-16) from Discount Tire on EBAY. Key is to buy a pair at a time and use the coupon twice.
#37 ·
My truck is going to need a set of tires this fall and I may have to try these out on it...
