I have a 1995 YJi with a 4.0. I don't have power to the pcm, no spark at the spark plugs and no power at the injectors. Im at a loss.... could someone help? Thanks joey
There are some differences in the harness pin-outs between a 4-cyl and 6-cyl...Thank you, what I have is a 95 yj with a 2.5 with a 5 speed, I swap it with a 1997 tj engine and transmission with a 4.0 with a 5 speed. I changed the injector to a 95 with other sensors so that the 95 wiring harness will fit. The only computer that I could find is out of a 1995 Cherokee with a auto transmissions. The wiring harness is in good shape an I'm think that the computer is bad. I'm going to try to ck it today! However I'm not to sure how to go about it? Any imput?
Where was the ground wire unplugged at ?Thank you all for the help. It was a ground wire that wasn't connected.its running good.
where was this ground wire disconnected at?Thank you all for the help. It was a ground wire that wasn't connected.its running good.
