O2 Sensor Heater Issue Solved
35K views 6 replies 4 participants last post by  Old Dogger
I've been having persistent issues with downstream O2 sensor heater circuit voltage issues (high and low) on both sides. Codes P0031, P0037, P0051, P0057.
With a lot of help from a forum member @lowflyer001 who patiently answered my questions and pointed me in the right direction, I think I've sorted the issue.
The root cause of the problem was that when my PO put a reman motor in the Jeep about 25k miles ago, the mechanic didn't ground the O2 sensor circuit to the body in the usual spot (behind the passenger side heat shield), instead they grounded it to a stud on the motor right by the knock sensor.
I did two things to fix it, I replaced the ground from the battery to the body, the old one was a bit dodgy, I then added a ground from the stud on the motor where the harness is grounded to the body behind the heat shield. I used pre-made starter motor ground cables (because they had really well made connections properly integrated into the heavy duty cables. The 19" starter grounds were only $6 each. Of course, over the last 9 months of tracking this issue down I've spent a couple of hundred $$ on new (unnecessary) O2 sensors, heat shields, and sundry other attempts.
Since doing this work all the I/M readiness checks have completed and there are no stored or pending codes. I really think this i the solution.
Huge thanks to lowflyer001 for all the help. This forum is awesome.
Ian
I can, but it'll be a couple of days a I'm on the East Coast right now and the Jeep is still home in SoCal. Also, not certain my solution will help you. I was getting downstream heater codes and the ground strap I put in was at the end of the downstream harness. That said, it still put a pretty solid ground connection from block to body, so maybe it'll still help you. I can try and describe it. Basically as you look at the bottom of the motor you can see a couple of sensors on the passenger side. By the rearmost of those two sensors there's a stud in the block with a ground connection. I took the nut off the stud and put a negative battery cable (purchased at O'Reilly for about $6) between that and the body ground point on the passenger footwell.
Ian
oh no rush. i appreciate the info, hopefully i have time to pull 'er into the shop tonight and have a look. i appreciate it may not be the silver bullet i am looking for but it's a start. i've got a few low key electrical issues to iron out otherwise since engine/harness/pcu/sensors have been replaced anyway, maybe this will help overall. haha.
Here you go, it’s a bit hard to see, but the what I did was bought a black battery ground wire from O’Reilly’s with built-in round terminals. I bolted one to the motor ground (passenger side of the block) shown here:
And looped the cable up to the body ground (engine compartment side of the passenger footwell) shown here:
This, plus cleaning up the grounds from the battery to the body on the passenger topside of the engine compartment got rid of my O2 sensor heater codes.
Ian
