Oil leak
1.6K views 8 replies 4 participants last post by  Electonictec
Just had a rear main seal and pill pan replaced as well as a front pump seal on my transmission and I still have an oil drip.(small one) it is coming from the same spot as before. Any suggestions? I had a local mechanic replace it.
#8 ·
If you saw it just after getting home from the shop its possible its just leftover oil from the work being done, unless its dripping out pretty heavily. I'd give the engine a good wipe down and wait a day or two before jumping the gun. If its just a super tiny leak, grab a bottle of Lucas stop leak at your local autozone. Best $12 you'll ever spend.
