I pulled the body off to start POR-15 treatment of the frame today. Lots of fun! Two body bolts acrually unscrewed--I cut the heads off the others and will use heat to remove what is left of the bolts. I couldn't use heat from the get go becasue I would have melted my rubber body mounts. I actually got a gallon of chasis black for the frame and antique silver for the Skyjacker lift arms and coil springs (It doesn come in Red and I wanted a different color than black), I also got some rust encapsulator for the inside of the frame that I sprayed in tonight. It comes from Eastwood in a can with a long nozzle that shoots the paint out in all directions. You pull it through your frame and it coats all around the inside.
Tomorrow is the frame painting.
My 14 year old daughter helped (she hopes to be driving this Jeep in a couple of years) and is in the pictures.
