New member so thanks in advance for advice. 2015 jku, other than the oil cooler that was replaced under warranty and a wheel speed sensor and a cam sensor this thing has been utterly reliable so far for 120000 miles. Passenger valve cover started leaking (it’s not the oil cooler) so I’m going in to do that, pcv, and spark plugs in a few weeks when we get to spring break and I don’t have to drive for a week. Should Ireplace the rocker arms while I’m in there? I have no ticking but seems like it’s a good idea to put the updated rockers in. But also feels weird to fix something that isn’t broken.
Any thoughts are welcome.
Regarding making preemptive repairs on my 2015 JKU-Rubicon (~45,000 mi), I had my original, plastic oil filter housing replaced with the Dorman aluminum housing before any problem developed.
But the issue of the rockers is a little more costly -- instead, I've followed the practice of
(1) upgrading my use of
AmsOil (which I've used on all my cars since the late 1970's) from
5W-20 Signature Series to
5W-30; and
(2) always,
after the car has sit for a day or more, starting in the morning by first
priming* my oil filter housing. I think that speeding up the oil pressure build-up may (I hope) extend the life of the rockers.
* by priming, I mean
fully holding down the gas pedal when cranking, which makes the engine turn at cranking speeds for about 10 seconds without starting the car.
I do this two times in a row, which (looking at the information screen set to display oil pressure) finally reveals during the second priming that oil pressure is finally achieved (there is still no oil pressure at the end of the first priming). Then, I start it normally. By this (my personal) rationale, the rockers during the priming with zero oil pressure rely on only some residual oil, but engine parts are only turning at a hundred or so rpm and because friction/wear is proportional to rpm, any wear is (hopefully) minimized.
