Pulling shrubs with a winch?
1 reading
27K views 22 replies 20 participants last post by  ParaCAD
I don't have a winch on my TJ and, while I would like one, I really haven't been able to justify the purchase.
Yet!
The QueenBee informed me this week that we really ought to replace all of our ratty old junipers and English Hawthornes that have been in front of our house for the last 15 years and give the place a fresh look. My devious mind immediately turned to the idea of parking my Jeep on the street (about 60 feet away) and using a newly purchased bumper mounted winch to pull those rascals out. I wish I could say that the shrubs are planted in some lush soft top soil but they are in some really gummy clay.
So...what about it guys? Anyone have any experience with a project such as this? Any advice would be appreciated. If you believe it is doable do you know what size winch would be appropriate?
Ive pulled out trees n such before. Not with a winch I just strap some chain around the base and hook it to my bumper or 2in ball . those bushes should come right out. Im guessing it would be a bit more fun with a winch LoL
PS just remember to dispose of all the shrubs in your neighbors backyard when hes NOT home.:rofl:
#18 ·
Just a word of caution...Never use a jerk strap on a ball hitch. If it breaks, you create a very nice slingshot that sends the ball hitch flying at high velocity.... Will go clean through a human being...
I know he says chain here, just putting that out there as there was a death in Minnesota two years ago from someone doing this...
#8 ·
Never winched them, but put a chain around them and used a strap between that and the Jeep. Used 4 low and walked them right out. You will have to dig around them and maybe whack a few of the bigger roots with an ax. Also, I cut all the bush or tree down to the last few feet above the ground, makes it easier to handle and lighter.
We've done small trees and brush, but always with a chain.
Usually with the pickup too.
I wouldn't use a winch for that. You might ruin it.
BUT, here's what you CAN do.
Go buy it and try it (not too hard, but make it look good, ok!) and say "DANG!! I thought that would work! Guess I'll have to use a chain or something.
Once you've USED it, you can't return it... get the idea? *wink*wink*nudge*nudge*
That way, you get your winch, you don't tear it up, and you get your bushes yanked out... eventually.
The other thing to consider here is SAFETY. If you get all wound up yanking on a bush and you snap a cable - if could really hurt someone. Not that it's likely to happen but just be safe.
Beautiful home by the way, absolutely beautiful.
Why not just prune the bushes?
#12 ·
I don't see why a winch wouldn't work as long as they aren't too deeply rooted...I've never done it, but when we pulled the big bushes in front of our house, I used our dump truck and a chain and barely had to give it any gas. It gently pulled them right out.
The last time I did it for my boss' neighbors we used a backhoe and a chain...and once again, didn't apply any gas...just idled backward and they pulled right up.
Now if you have some deeply rooted stuff, you may not have much luck...as plan B (so you can still get your winch...lol), what about using a strap and pulling them going across the yard rather than toward the road? Just throw it in 4LO
#14 ·
I used my winch to pull shrubs, some pussy willow bush/tree things and also a small apple tree. Worked fine. I tried with 4Lo but ended up spinning the tires, which meant more work repairing the yard. For the apple tree stump, I soaked the ground a couple hours before hand to try and soften up the hard clay soil in my yard, which seamed to work. I didnt use a chain, just the stock winch cable and a tow strap. Also make sure to put something over the line to reduce the cable whipping back if it were to break, same as you would if you were winching you jeep out of the mud. I have a Warn XD9000i
Also, I didnt let my tranny hold the jeep in place, I used the brakes.
#15 ·
Wow....great responses (as usual) from all of you guys. The complicating factor in pulling the shrubs out in 4Lo is that I will have to keep the Jeep on the street which means I will be looking at a pretty long chain/strap, etc. (at least 50 feet). It does sound like the winch wouldn't work but...as was suggested by many....it would be a shame not to buy one and give it a try!!! :D
Thanks again, ya'll.
#16 ·
I used a winch to pull out some junipers about 4 years ago from a house we owned in SD. It worked good, but did kill the engine a few times, so keep a battery charger/starter handy. The winch was on the front of a fire truck ( 1 ton Ford brush truck) from the local volunteer dept that I was a member of. I don't know how big the winch was, but I wrapped a chain around the stumps, and let her pull. I usually had to hook on from a couple different angles, and it helps if the ground around the stumps is well soaked.
After that, it was no-no to use the fire trucks to winch out shrubs. We lived on a main street and numerous people saw me pulling the shrubs, and wanted the VFD to pull their shrubs, for a donation, also!
I had premission to use the truck
#17 ·
There is NO bad justification for major Jeep upgrades/enhancements so long as it gets the wife to sign off on it. So spin your wife's "honey do" list into a not-so-subtle suggestion:
"Gee, sweetie, it's funny you mention removing the shrubs. I have already been thinking about installing a winch on the Jeep, and if I had one it would certainly help me to remove all the shrubs and bushes around the house. Even better, the winch would be able to reach the shrubs from the street, thus ensuring I don't tear up the lawn in the process. Doesn't that sound great?"
As soon as she agrees, pick up the phone and order your new Warn winch!
Oh: if you're worried about burning up the motor, just use the winch cable to reach the shrubs (much like a conventional tow strap), then pull them out by backing up in 4LO. Unless your wife is a seasoned Jeeper, she'll see that you are using the winch cable and thus assume you're just using the winch in the conventional way. :D
