I am going crazy trying to get my brakes back together after a total overhaul. New hard and soft lines, new master cylinder, proportioning valve, shoes & springs etc. Used the original wheel cylinders and calipers as they looked good. After numerous attempts at bleeding, I cannot get a firm pedal at all. It seems like I can pump up some pressure but nothing like it should be and when I start the car, the pedal goes to the floor with no resistance. I carefully bench bled the MC and gravity, vacuum and manually bled the brakes. I am reasonably sure there is no air in the lines. I adjusted the rear shoes to have some resistance but this morning I took off the rear drums to check things out and noticed that only the leading shoe moves when the brake pedal is pushed. Shouldn't both front and rear shoes move? Meaning shouldn't the rear brake cylinder push in both directions from each end? Attached are a couple of pictures of the driver's side in case someone can spot something I have done incorrectly.
Any help would be greatly appreciated!!!
