Radio won't start
6.8K views 11 replies 8 participants last post by  Jeeprich25
Hi,
I'm new to posting on the forum but have followed the sound advice here for awhile now. I have a 94 YJ. My question is regarding my after market radio. It worked fine, memory retained programming and all, no problems until I put in a new starter. As my friend installed the new starter he was shocked due to my key just sitting in the ignition in off position. I'm wondering if something's wrong with the wiring. Jeep starts fine now. I noticed after starter was installed radio wouldn't turn off even with key out of ignition. I removed the radio face to stop it. Next day no radio at all.
I had had a previous problem with rain leaking in the hood cowl rubber thingy but it was corrected before radio died( thanks to this forums help) Perhaps water affected wires but I'm thinking it's more related to installing starter.
I checked all the fuses, under hood, under steering wheel, and on radio itself- all fine. I took cable off battery and rechecked battery cable but it's fine.Any one know what else I need to check? :happyyes:Thanks, any input is welcome.
Get a meter or test light. Verify that the constant and switched hot lead behind radio have juice and that the switched one does indeed lose power with the key off.
Check the dome fuse under the dash. That is what the radio is powered from. Did your dome light stop working too?
For the love of god when working on the electrics, disconnect the negative terminal from the battery.
Get a meter or test light. Verify that the constant and switched hot lead behind radio have juice and that the switched one does indeed lose power with the key off. Check the dome fuse under the dash. That is what the radio is powered from. Did your dome light stop working too? For the love of god when working on the electrics, disconnect the negative terminal from the battery.
I agree with Fabrokoner. Always disconnect the battery when work on electrical.
my dome light and radio quit work after big bump on the highway one day repleaced the radio senece it said 95 on the back and nothing memorey wire didnt have power i ran a wire to the radio fuse on the fuse box and now i got memery but Fabrokoner says dome light fuse is this same as under dash lihts thats what im calling dome light this makes sence because there is no fuse where it says radio never has been sence i owned it there is a wire i think for my alerm in there though and now my new memery wire i would like my lights to work again and remove said wire because i know ots wrong way to do things goin to check fuse now
