Removal of upper control arm bushing off Dana 44 axle housing
6.3K views 8 replies 9 participants last post by  RobertLJ
Happy Monday to all!
Any new methods developed lately for the removal of the upper control arm bushing that is part of the Dana 44 axle housing - 2004 TJ Rubicon?
What was your most "successful method"? On the ground OR on a lift (I have access to a lift)?
Has anybody experienced using a short barrel air hammer? Were you able to manipulate it in the given space? What were the results?
I am not convinced about the "drilling the rubber out" method I have been reading about, as I do not see how a drill will fit in the available space.
New opinions?
Cheers,
Ben
Not sure on the D44 but I've removed them from a D30 (probably very similar). I didn't drill the rubber. Some Parts Blaster. Pneumatic air chisel mosty, ball joint press can help if you can get it to fit and have the right sized spacers. It's a bit of work no matter how you do it, no real way that I know of to finesse them out. Mine were mangled once I got em out.
Hammer and a drift works OR yes drill the rubber... you might need a right angle drill
#8 ·
After doing some with an air chisel and Sawzall, I've found the most successful and easiest method is what I did with my XJ.....I paid the mechanic down the street $50 to replace them. It kept the neighbors from hearing all the four letter words I know.:censored:
