Replacement TPMS sensors?
1 reading
6.1K views 5 replies 5 participants last post by  deepbluerubi
Does anyone have any experience with the cheaper aftermarket TPMS sensors on Amazon? I’m getting new wheels and tires soon, and was thinking about buying new sensors as well, so I can keep my old wheels complete. What brands are good/decent? I don’t want to spend huge bucks on OEM sensors if I don’t have to.
#2 · (Edited)
What year? They changed the frequency in 2011.For 2007-2010 should be 315MHz, for 2011-2018 should be 433Mhz.
Don't forget the spare. Most of the sets are 4, this link is to a set of 5. I am still running my originals as they were transferred from my factory wheels (in storage with the original rubber stems) the sensor/transmitters where screwed onto the metal valve stems on my new wheels. I have not had to replace any yet. When I do, this is one set I will try.
I have had good service from Schrader TPMS sensors on two different (non-Jeep) cars. They are a supplier to many OEMs. Specifically, I am using the Schrader programmable EZ-Sensors for winter/snow wheels/tires on a Honda and a Toyota that are too old to auto-detect TPMS sensors, so mine are cloned to match the OE sensors on my summer wheels/tires. They make OE replacement sensors for Jeeps.
Well they ain't cheap. I mean anything that just reminds you of your tire pressure shouldn't cost an arm and a leg but they do!
Guys had good luck with quadratech ones on here. Me, I just buy oem. I don't want to be pulling wheels on and off and having tires partially dismounted. I've replaced one in the almost 13 years of owning my jeep. I guess if you air down a lot and they are going off you will shorten the lifespan. I would look into the Schrader brand option if it would save some money. Good chance they are an oem supplier.
