Have some questions about rocker arms in 3.6 and I thought I would ask to see if anyone had info.
2013 jku, 115k miles
I noticed the engine ticking really slightly about a month ago, couldn't really hear it out in the open at idle but next to a wall at a drive through I could hear it. Over the next 100 miles or so it got a little louder and was coming from the passenger side towards the firewall. I knew where this was heading so I ordered a full set of 24 Melling rockers and lifters, along with all the gaskets on the valve covers and intake. Got the chain release tools and cam sprocket blocks off amazon. 12 hours of under hood work spread over 2 evenings and a rainy Saturday and it's all done and quiet again. It's not a bad job if you have tools and some patience. 1 rocker bad enough so that the roller carrier had just touched the cam lobe. 3 more that had a little bit of extra clearance but not bad enough yet to make noise that I heard.
So a few questions to see if anyone here knows.
Who made/makes the rockers for Chrysler in 2013 and mopar spares now?
The rockers I took out had the pins pressed or crimped into the carrier with the roller spinning on needle bearings, load is always on same side of pin. The new Melling ones are almost identical externally except the pin is free to rotate in the carrier. Do current revision Mopar replacements still have a stationary pin or is it free to rotate?
Anybody know the steel type used on the roller and pin? Precision bearing races are usually 52100 steel but a variety of lower cost steels will reach appropriate hardness levels. I have made custom rocker pins for racing engines from S7 with excellent results in both wear and break strength but I doubt production pins are this good.
From what I have read this has been going on for a while with pentastar engines. It is an obvious design failure in either material selection, component design, or quality control. Possibly a combination of the three. For those who would say it is "normal wear", no, rocker failure of this type in a maintained engine is not even close to normal. The Chrysler engineers know for sure by now what the cause is, anybody know their official answer?
Less than $500 worth of parts and some garage time took care of it for now. I also got a chance to see just how clean the inside of my engine was and it was cleaner than I expected.
Would be interested to know how many of you guys have had to do this repair or have it done and at what miles.
