Do I need a slip yoke eliminator on a 4 inch long arm lift from teraflex?
x2.The straight answer is that on a SWB TJ like you have, 4" and taller is when you need a SYE kit to be installed into the transfer case and a CV driveshaft.
The bolt hole doesn't need to be perfectly centered, it just has to be good enough so it can be threaded in through the yoke's mounting hole. That bolt only has to hold the yoke on. The H&T yoke is splined so it self-centers tightly and perfectly around the splined tcase output shaft so it will always spin perfectly true even if its mounting bolt isn't perfectly true. It's a pretty genius design that makes its installation hard to screw up.And I don't know about you Jerry but I'm not the best at drilling a centered hole.I bought the sleeve that slips onto the output shaft and assures a centered hole.But you could just use the flange to guide you
ANY shop that tells someone a 1" tcase drop is usually enough to prevent vibrations from a 4" suspension lift just doesn't know what they're talking about. A 1" tcase drop by itself is not usually enough for even a 3" suspension lift. And what exactly are they providing for that extra $100??? $100 won't get you a SYE and CV installed.I had a 4" lift installed at a local shop. They told me that if I get a 1" transfer case drop I won't need a SYE. Turned out that my jeep is fussy, and I was getting a bad vibration. When I had them take another look at it, they said that it's not usually needed, but in this case since they told me I didn't need one, and I actually do, they ate the cost of it 100.
Tom Wood or Adam's drive shaft...Jerry, what CV driveshaft would you recommend? Trying not to spend 700 on a driveshaft, but for every 4 comments lauding a driveshaft in the 350-400 range, there's one that says it blew up after no time at all. Would you say that is more due to a poor installation job or should I be wary of CV shafts in that range?
Thanks, I had a feeling that was likely the case. The kit I got does have adjustable CAs, and I bought a SYE from RC already--I know you get what you pay for, but I ain't exactly rolling in it as an E4, haha. I'll give Tom a look on that one.Too many CV driveshafts are installed by those who have no clue how to properly change the rear axle's pinion angle to meet the different pinion angle requirement of the CV joint.[/url]
