You'll most likely need a SYE. Each vehicle is a bit different and some Jeepers have come up with a work around but with a 4" lift, the SYE is the most common cure for the issues that might arise.
Jeep Wranglers typically have a short wheelbase. This contributes to steep driveshaft angles. When you install a spring lift, it increases the steepness of the driveshaft angle. It's easy to lift a Wrangler far enough that the extreme angle causes vibrations. A 2 1/2" lift is generally considered the max a person can lift a Wrangler without a Slip Yoke Eliminator.
What a SYE does is replace the stock tailshaft housing of the transfer case with a shorter housing. This also requires replacing the TC output shaft. With a shorter tailshaft. You need a longer driveshaft, thus reducing the angle of the driveshaft. The longer driveshaft has an included slip yoke and a double cardan joint. There are typically custom made for the particular Jeep that's getting the SYE. Tom Woods is a good source for a custom drive shaft. You'll also have to shim the rear axle at the springs to raise the pinion shaft angle.
Google Tom Woods Driveshafts for a better description of what needs to be done.
Good Luck, L.M.
