Just bought a 2009 Wrangler and dropped it off to the dealer to inspect it. They want to charge me $2,200 to replace both front and rear drive shafts because the $10 boot is torn. Why are there not more people simply buying a new ruber boot, cutting it in half, putting it over the drive shaft, and either epoxying the seal together or using some type of adhesive? Is there simply no other product that allows you to repair the drive shaft in place? There is nothing wrong with the entire drive shaft at all. I've also read where Tom shafts do not even use a boot - so does anyone know of some inexpensive fix / solution for the torn boot?
