Torque Values For Rear Suspension Components ???
1 reading
11K views 3 replies 3 participants last post by  cdeslandes
Anybody have a list? Trying to trace the clunking noise after my Jeep was lifted and I want to re-torque everything back there myself. Sway bar links, shocks, control arm and track bar. Thanks.
track bar and control arms 125 ft/lbs work and swaybar links and shocks guttentite but around 50-60ft/lbs work.
owns 2024 jeep wrangler rubicon
Per service manual:
Shock Absorber Upper Bolts 37 Ft. Lbs.
Shock Absorber Lower Nut 65 Ft. Lbs.
Suspension Arm Lower Axle Bracket Nut 117 Ft. Lbs.
Suspension Arm Lower Frame Bracket Bolt 117 Ft. Lbs.
Suspension Arm Upper Axle Bracket Bolt 125 Ft. Lbs.
Suspension Arm Upper Frame Bracket Bolt 117 Ft. Lbs.
Stabilizer Bar Retainer Bolts 52 Ft. Lbs.
Stabilizer Bar Link Nut/Bolt 75 Ft. Lbs.
Stabilizer Bar to Link Nut 66 Ft. Lbs.
Track Bar Frame Bracket Nut 125 Ft. Lbs.
Track Bar Axle Bracket Bolt 125 Ft. Lbs.
