Trying to decide between these two compressors, and looking for real world experiences. I am looking at the portable versions of these compressors.
I need it to fill 32 and 33 inch tires on Jeeps and a couple of 29 inch tires on my trailer from 15-35 psi. I also want to be able to seat a bead and refill a tire to 35 psi. I will probably never use this compressor to fill tires larger than 33". It is likely to only ever be used for filling tires and air mattresses and that sort of thing.
I know that the 400 is the faster compressor. I also know it has the lesser duty cycle, but that in practice at 15-35 psi I will probably never have it shut down due to heat.
My main question is what is the difference in heat between the two compressors? Does the 400 get substantially hotter than a 450? I've read stories about people not being able to put 400p's back in the bag after a fill up because they were so hot. What is the cool down time after use for these two compressors? When are they safe to stick back in the portable bag?
If the 450 and 400 both get really hot, I probably would go with the 400, but wanted to see if there was anyone out there who could compare the two.
