What would be the best shocks for a currie 4 inch lift ?
16K views 28 replies 23 participants last post by  DougRz
Best shocks ? Aaaaannnnnddd go !!!
I just put in the 4 in currie lift on my TJ. I went with the Bilstein 5100's.. Love the ride and lift.
OME, because they're yellow.
#17 ·
Rancho rs9000xl 9 way adjustability, made in USA and lifetime warranty yeh buddy I like mine a lot
#19 ·
I believe the currie coils reach bind at 4.5". If you run your axle up to that point, you could measure for your shocks compressed length.
#20 ·
I ran Bilstein 5100's on three different Jeeps, and plan to swap out the Pro Comps on this current build.
#21 ·
5100's or 9000's. I currently have the 5100's on my TJ and am happy with them when the hard top and doors are off. When the Jeep is loaded down it could use a stiffer/adjustable set up. I ran the 9000's on a prior set up and my current tow rig(2500HD) and really like them.
#24 ·
A well-known Jeep builder and suspension designer I know once opined this on the Bilstein 5100. Install them if you want to know if the quarter you just drove over was heads or tails. :)
#22 ·
Bilsteins are great for a heavier vehicle. They are a poor shock for the TJ in my opinion. I have 5100s and they are way to stiff. I recently drove a jeep with Ranchos in the front and tuned foxes in the rear. What tosses me out of my seat I couldnt even feel in his.
#26 ·
I ran them for a couple of years, and then installed a set of OME Nitrochargers...night and day difference. The Bilsteins are very harsh on low-speed, small movement type of events. Small bumps, cracks in the pavements, etc. The Nitrochargers are a LOT smoother, in comparison. I never have a concern, even over a washboard type road...with the Bilsteins, I always wondered if I was going to loose it because the suspension couldn't keep up.
#29 ·
9000s on mine. Really like the adjustability. Rancho runs rebate deals occassionally if you can hold off. Mine ended up at $60 or $70 each iirc.
