Should Jeep's 3.6L Pentastar Engine last over 82,000 miles and should they give a goodwill payment?
1 - 1 of 79 Posts
Stellantins doesn't owe you a thing just because the rep told you
"I forgot to mention that because your vehicle is at an independent repair facility and repairs would be out of pocket regardless of the decision made on goodwill, I would have your mechanic order the engine to forego any more time lost. The case manager, if reimbursement is approved, would be simply be approving based on the repair order from the repair facility you are using to determine the point of failure and that the repairs would be covered by the appropriate warranty."
This is not binding stellantins a single bit to you. it seems to imply you understand what you're doing, you will be paying out of pockets barring a decison that haven't been made regarding repairs and engine or whatver it's both of you're are discussing....
All you had to do was ask, What if the reimbursement wasn't approved? before you went ahead an order the engine.
Reactions: comanchepilot
1 - 1 of 79 Posts
