I've searched the forums and there are a number of posts and threads covering the "Death Wobble", however, it seems like there isn't really a solution posted.
My thinking is this may be an issue with larger tires and then shocks failing, once you hit a sufficient bit of rough road and the "correct" speed the jeep displays the Death Wobble, thus requiring you to slow down, maybe to a full stop, to spot the wobble.
My thinking is that the shocks fail in a manner where they don't leak, and you only see the issue when there is a sufficient amount of force on them - "high speed", etc.
My Death Wobble starts at about 65MPH, and isn't dependent on if I'm towing, or loaded down with gear.
Does anyone with STOCK sized tires see a Death Wobble?
