I'm having front end vibration, like a bouncing up and down motion like you're driving over the little road reflectors repeatedly. It doesn't happen all the time but it happens every drive, even on a brand new paved road. It is NOT death wobble, I have experienced death wobble in my own JK and in others, this is not it. My wife no longer wants to ride in the Jeep because of the vibration. It does not affect driving or handling, it's just really annoying and apparent. It can happen at any speed, 15 mph or 55 mph, it happens, sometimes it goes away when you let off the gas, other times it doesn't.
I have had two alignments and tire rebalancings in the past year, I installed everything myself, I can't remember when the bouncing started. EVERYTHING has been gone over 4-5 times to see if anything is loose but nothing is. Tire pressure is 32-36psi.
---All of the below has been installed within the past year---
-JKS JSPEC 3.5 in JKONNECT suspension system with leveling kit so total about 4.5 in
-Adams 1310 drive shafts, front and rear
-Powerstop rotors and pads
-All new calipers
-All new braided steel brake lines
-New front and rear axles (Complete kits with U-joints in front and bearings in back)
-New front wheel bearings
-2" Wheel spacers
-32" Toyo Open Country A/Ts on some XDs (Haven't pulled the trigger on something bigger yet because then I won't fit into garage).
-Front and rear bumpers, winch etc (not sure if relevant this has been on for 3 years)
Only thing that hasn't been replaced is the tie rod and the tie rod ends, everything is super tight and I do not believe that's the issue but am open for opinions.
In my father's opinion he believes the tires are "hard as f#$k and make it vibrate." I don't know.
Any ideas?
-All new calipers
-2" Wheel spacers
Any ideas?
