Full doors YJ vs TJ
26K views 17 replies 6 participants last post by  1995YJ Rig
I have an opportunity to get rust free door shells from a 2000 TJ. I have a 1990 Wrangler I'd like to make them fit. I've read the strikers are different. Other than that would the doors work? They're rust free and I can get them​ for next to nothing. I'll need to get the latches, regulator, and glass to complete them. Will these doors fit the opening? Someone tried to tell me that the windshield angle is different. Doesn't sound right because we can use TJ uppers(modified pins to fit a YJ half door) on a half door to fit a hard top. If these can be used, I know that someone here has done it. Lemme know ok please. I'd hate to pass these up and regret it later.
Different striker plus different inside handle location so that with YJ doors on a TJ speaker girls block inside handle access
Also YJ have vent windows and outside flipper handles open opposite way so that a right outside door handle for a TJ is a left outside door handle for a YJ
But yes should fit the opening
#8 ·
yj with tj hard top & doors
so was wondering if any one can tell me if you can put a TJ hard top and doors on a YJ I got a hell of a deal on the hardtop from a TJ and I am looking for TJ doors but before I buy some would like to know what strikers work for the swap and any other issues I may run into with this project pics are a great help
Here's another​thread that will help show the strikers you'll need.
Difference between Full doors YJ vs TJ - JeepForum.com
#11 ·
Went and picked up the doors. Not as stripped clean as the seller made them sound. He actually found the one door glass and a box with handles, weather stripping, window crank handles, the hardware, and some mirrors. All for $150. I'll need to get one window glass and the interior panels. Not bad for the price.
#12 ·
Fix up the tj doors n sell or swap em for yj doors...
You'll see when you try to put em on that the way they fit the tub is different.... tj tops n doors are pricey n cj/yj stuff can be had cheap.
#14 ·
Switching half doors to full doors or vice versa is a total and complete Cluster muck. What a waste of time and effort trying to make that happen, never again...
#16 ·
I got half doors for my 95 off another 95( i have full doors) and would not fit, the hinges were all different, i cant believe Jeep did that. I wasted a whole day trying to figure that one, at least you decided to ask first.
#17 ·
There are more adjustments to the doors than some people realize. I've done body work in the past so I'm up for the challenges. I know folks that have their doors set to where they can swap to them out and full and half doors are adjusted the same. Takes patience and time to adjust it there.
