Great info! That's the problem with these JK heater discussions. The symptom is always the same of cooler air blowing from the driver's side vent but that all boils down to a simple diagnosis of the heater core not having enough hot coolant inside of it to fully distribute heat across the dash vents. Then you need to get into the real trouble shooting dianosis of determining the reason the HC is either blocked or there is a leak somewhere and therefore has air inside of the HC and therefore the HC is not fully filled with hot coolant. In your scenario, there was a leak in the oil cooler, which led to low coolant and air inside of the HC.
In my particular instance my trouble shooting went like this.
1. Observed cool air was blowing from driver's side vent.
2. Noticed my coolant was low, filled and burped coolant system....heat improved for about 3 days, then cool air again from driver's side vent.
3. Observed coolant was low again, identified leak in radiator, replaced radiator.....heat improved for about 2 weeks, then cool air from driver vent.
3. Observed coolant was low again, identified I had a lower-intake manifold gasket leak, replaced LIM gasket....heat was better for about 2 months.
4. No longer observed coolant was low, but cool air still blowing from driver vent.
5. forward and backward flushed HC, no improvement.
6. removed HC, cut it open and observed it was jam packed with engine casting sand. Replaced HC and finally had heat like I remembered when new. Been good for the past 2 years now.
So the symptom of cool air blowing from driver's side vent was always the same but I ended up performing 4 different fixes before I was able to get heat back to working properly.
