Is having "Xtreme Recon 35-Inch Tire Package" From Jeep for 4K worth it?
45K views 112 replies 33 participants last post by  jeeper6255
Hello ,
I am new to this forum, and I am looking for some suggestions/Recommendations.
I was planning on getting a new Rubicon, Jeep's website lets you have 35s on the vehicle for an additional 4k with the following upgrades:
$3,995
  • 110-MPH Vehicle Max Speed Calibration
  • 17-Inch x 8.0-Inch Beadlock-Capable Wheel
  • 35-Inch Tire Suspension
  • 4.56 Rear Axle Ratio
  • Anti-Lock 4-Wheel Disc Performance Brakes
  • 3rd Generation Heavy-Duty Dana® 44 Front Axle
  • GVW Rating - 6,100 Pounds
  • LT315/70R17C 113/110S Tires
  • Hinge-Gate Reinforcement by Mopar®
  • Jack Spacer by Mopar®
  • Tire Relocation Kit by Mopar®
  • Wheel-Flare Extensions
The idea of getting the 35s are for the aggressive looks. Might go on for some trails or off roading. But will be using this vehicle for daily commute. I know it doesnt make sense to use 35s on daily commute, but they just look amazing.
I dont think the package includes lift kits.
Would it make sense in getting the tires replaced out of dealership and what would be the cost in getting a tire package something similar to this?
Would 33s on the Rubicon give that look and be more practical for a daily commuter like myself?
Thank you.
I am currently in the process of pricing outfitting my Rubicon with 35’s. The cost of wheels, tires, lift, and heavy duty hinge with spare tire relocation is going to run me about $7K. Don’t get me wrong, I know it can be done for less, but not to have it done the way I want it. And I’m not including a regear at this point which would add another thousand to the price tag.
The only way Jeep is able to sell this package for that price is the fact they are saving the installation cost associated with doing it aftermarket and they are substituting parts instead of paying for the stock parts and the upgraded parts.
In my opinion, if you like the wheel and tire combo they are offering with the package, it’s a good deal.
By the way, the stock tires on a Rubicon are 33’s.
#7 ·
Welcome to the forum.
The XR package gets you lower gearing; but it doesn't get you the Mopar 2-inch lift which, IMO, is a must-have with the longer springs, beefier Fox shocks and the longer control arms.
Everything else, the wheels and tires, you can easily get on your own.
I paid $2,000 for the Mopar lift, and $2,000 for wheels and tires which, combined, is the same price of the XR package..
So basically you have to choose between getting the lower gearing installed at the factory, or the Mopar lift installed by the dealer. Take your pick.
I wouldn't do both.
Good luck.
#8 · (Edited)
4.56 Rear Axle RatioAnti-Lock
All these thing would easily cost double if you pieced mealed it. Well worth it.
Post Script: After market 35s and or 4:56s would severely test the the warranty parameters. As a factory option your totally covered.
The omission of the Mopar lift is a big deal, IMO.
The “35-inch tire suspension” is nothing more than the regular Rubicon suspension stretched out another 1.5 inches. It reuses Rubicon’s so-so red shocks, and adds the long bump stops from the EcoDiesel, which severely limit wheel travel. I honestly don’t get it.
You are better off buying a regular Rubicon and adding the Mopar lift: you will get longer springs, better shocks, more height, a smoother ride and greater articulation.
#11 ·
I paid more than $4k for just my wheels/tires. My regear was about $1600 so yes, its a pretty good bargain at $4k
Reactions: GCAL
#12 ·
thats actually a pretty cool package. I personally daily 37s on 4.88s kind of a dog wish I went to 5.13 but its great on the highway. if you're going to stay at 35s I personally would do it. saves you the headache from buying and installing all the parts. my only gripe is that tire size is not really a 35 if you ask me especially if its a BFG
#13 ·
If a guy pays $3,000+ for wheels and tires alone, he's not doing it right.
Reactions: AustyPosty
#14 ·
What wheels and tires are you buying that cost significantly less than that? Used doesn’t count and we’re talking about 5, not 4 on the ground and a tire cover so you can’t see the mismatched spare.
#22 ·
In case you guys haven’t seen the “35-tire suspension” included in the XR package, here are some photos from another forum.
Notice Jeep carefully avoids using the word “lift”— it retains the standard Rubicon red shocks, stretched a further 1.5 inches
But wait, there’s more: it also uses the long-ass bump stops from EcoDiesel. Look how little articulation is left!
Yes, the package includes a reinforced front axle, but IMO Jeep dropped the ball by simply stretching the existing Rubicon suspension and then adding those humongous bump stops to keep things under control. It all looks like a rushed job.
My guess is Stellantis will “update” the XR suspension in a year or two, once it had time to properly test and develop a new suspension.
I’d wait until then before ordering this package.
#31 ·
It's always a funny comparison given: Is the $4,000 delta worth. Diabolical isn't it? It's not like we are buying a Jeep with no tires and wheels. I would imagine you could get $1200 for Rubicon or Willy wheel and tires as take-off no? Kinda bothers me they simply stretched they 1.5". That said, lol, I'm leaning towards the Xtreme package 🙄
#32 ·
Well here’s the deal. The Xtreme pkg is actually not about the wheels, tires, or even the lift, it’s that front diff.
HD wide M210 D44, thicker tubes, 4.56 gears, steel cast knuckles rather then aluminum and 392 big brakes all round. This is the 392/Mojave set up. That alone is worth $4k. Lift, HD tire carrier and tires is just the bonus…
Does everyone NEED that heavier front diff? No, not necessarily but even doing aftermarket big brakes and a gear swap is starting to get you close to $4k. Add in the lift and 35s and you are over $4k on that end.
#33 ·
Hello ,
$3,995
Thank you.
With all thats listed its definitely worth it. Just the axle up grade alone is worth that. Gear change to 4.56 with 35 inch tires will allow everthing to operate at optimal ranges you wont be able tell the difference from a stock jeep. And the looks is much better. The gear change alone would cost around 2k+
#36 · (Edited)
Oh just wait, if the package is as popular as it appears to be once everything catches back up with the shortages I am sure this package will be available with manual trans as well. It’s a tough time right now.
For those that wonder if it’s worth it. An aftermarket front axle swap is $6-8k alone. Even if you sell your factory front axle for $2K you are still not ahead doing it yourself. That right there pays for the complete XR package. A gear swap $2k, average tire and wheel package $3k, big brake kit $1K, and then all the little extras like tire carrier etc $1k
#38 ·
I think it is worth it. If I may add, it is all connected to a 3 year(36,000) warranty.
Now, if they will just build these damn Jeeps for us, so we can challenge them!!!! lol
Mine is in shipping waiting to come home.
