JK regear
8.5K views 24 replies 12 participants last post by  rsmwrangler
I was thinking of doing the regear with my brother in law who is a mechanic in his spare time and works at a Ford plant in KC. I got an estimate of $2,400 to have it done, but online Exodus 4x4 on YouTube is saying they do it for $1,500…which is more inline with what I imagined it should cost. Can and should we attempt it, and if not is there a shop nearby that comes in at a good cost?
going 4.56; I’m running 35’s on a 5 speed automatic
Two comments, I had my 2013 regeared in Dec and it cost about $2300 (there was a regear special at the time) for both front and back. Prior to that I had been quoted between $1000 and $2000 per axle depending on where I went. Apparently the cost varies around the country with some areas higher and some lower. I have been told multiple times that 4.56s are recommended for 35" tires and the automatic but to consider 4.88s if I intended to tow at higher elevations or eventually go to 37" tires.
#3 · (Edited)
The prices of parts and labor have gone up just like everything else. I had mine done is 2016 and it was $1400 and was a good deal. A good deal today would be around $1800.
As far as you attempting it or not it comes down to how patient you are. It is not hard with the proper tools but it does take time.
Reactions: AustyPosty
My husband is not a mechanic but might as well be. He's rebuilt engines, trannies etc etc. If it can be modified or re-built he's done it. He won't do a re-gear again. There are some specialty tools you'll need to factor into your budget. Unless your BIL has a bearing press laying around- amongst others. I am firm believer in experience counts- there is "how to do it" and then "how easy the guy who has done it 100 times" makes it look. If I needed a re-gear on my JL I'd spend $1500 no doubt. Though I'd certainly shop your area for pricing.
You definitely can do a regear yourself. I did mine with good results. There are some tools that are either necessary or will make the job a whole lot easier. If you have to buy those, then the economics of doing it yourself probably won't really pencil out. Maybe you will save a few hundred bucks, buy you will be putting in a lot of time and won't have any warranty in case there's a problem. So if you are just doing it yourself to save a few hundred bucks, then I would recommend that you have a shop do it. But if you are a DIYer and there's value to you in learning new things, then go for it. I recently set up a new set of axles for my jeep. Since I already had the tools from the first regear, and the knowledge learned, it was a fairly easy and enjoyable project.
#11 ·
As part of selecting a shop, check what the warranty terms are if you supply the gears or if they will only give you a full warranty if they supply the gears/install kit as well. That's been an issue for a few members here in the past. I'd also agree with installing a locker while you're in there--why pay for labor twice. Good luck.
#18 ·
I paid $1000 OTD back in 2015 on my 1st Jeep. Now on my 2nd Jeep i paid $1200 OTD in Jun 2021, that's everything parts, labor taxes etc etc. Used the same dudes, and my shop doesn't keep the Jeep for 3 days lol. I was in and out in just couple of hours from 3.21 to 4.56. they did my rear locker last month. One hour to get that installed. (locker install only i did the wiring msyelf)
