Figured I would post pics of the JL hood latch install on my JKU, since there are several related posts on the subject.
It's easier if you pop the grill back in order to reach your hands inside the side fenders. It's one bolt for the base latch (13mm) and two bolts on the hood (10mm).
The JL latches I bought on amazon were $30 (free shipping, no tax).
https://www.amazon.com/gp/product/B07H94WH72/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
JKU OEM Latch
The new latch has molded pins to line up with the body. Obviously, these don't line up, so I just cut them off. The tab on the top of this part of the latch is enough to help align with the body and keep it from rotating.
The original hood latch portion that attaches to the hood, has a protective plastic layer. I cut at the yellow line so that the new latch will look nice. Otherwise, you'll have a loop at the top that sticks out above the base of the hood latch.
And the final pic of the install completed.
JKU OEM Latch
