I want to install the air lift 1000 air bags in the rear with the TF 2.5” spring lift. The TF lift kit comes with spring retainers for the rear in which the bolt fills the hole where the air bag hose is supposed to run through. It seems like I have two possibilities. One is to run the hose out of the top, thereby installing the air bags upside down from instructions. Not sure why this wouldn’t work. The other would be not using the spring retainers and installing the bags as per the instructions. Are the retainers necessary? It seems like since the springs are longer than my stock (albeit only 7/8" longer than my Rubicon X springs, quite disappointing by the way), that retainers wouldn't be needed since I didn't have them stock.
For clarification, the air lift 1000s are for increasing payload ability for towing my boat short distance, not for increased lift height. These worked wonders on my Ram.
Thoughts?
Thoughts?
