I am at a loss as to what to tap into with the two leads from the switch. Not an electrician, help!
What makes you think they are backwards? Anyway you agree that the green blue are the in/out. Question - the switch panel is grounded at the batt. but you say I should run another ground to the solenoid, I'm confused.I am curious why the blue/yellow color-coded wires are reversed at solenoid. could be they were just assembled backwards
Thanks for clearing that up, I really appreciate it 👍Let's look at it this way.
The winch currently has two separate electric processes.
- 1. solenoid pac with the small wires to signal winch motor via the bluetooth and connected handheld controller.
- 2. Winch motor that controls the cable
Say the two are separate functions.
The winch motor gets its power from the large ga. wires from the Battery, 12+(Red)and 12v-(Black). That's all it needs to run the motor, but nothing tells it which way to run, in or out.
Enter the Solenoid circuits
The solenoid terminals take low amperage 12v wiring. You need 12v to activate the solenoids at the winch, Usually you get that 12v from the 2/4/6ga wires from the battery at the winch (in your 1st pic you can see that where the sm. red wire is connected to the large ga Red Terminal.). Your Supplied controller is what completes the directional circuit to signal the winch motor which direction to turn.
All it does is close a heavy duty contactor in the Winch to run the motor in the desired direction.
Enter your Rocker Switch. A third electrical function which would serve you best by being wired independent of the Warn electronics. JMHO
All you need is to provide 12v to the directional terminal (Blue or Yellow on the controller) from the harness you designed.
You have a choice.
Option 1, run a 12v signal from the winch main 12v terminal (Reds) to the switch and back to the yellow/blue terms on controller. (3 wires) 1 12v+, 1 in and 1 out
Option 2. use 12v at light switch bank to supply 12v and run (2 wires) 1 in, and 1 Out to front via harness.
The question is whether you want the winch to run on demand hot all the time, or off of a switched key on source.
Digest this for a minute and see if it helps..
Here is the end result.That's exactly how I would do it.
Might have skipped the tap/slice things and went to something more like this.
But what you've got works good too. Just in case the poles are reversed.
