What lift kit has a REAL SOFT ride???
47K views 18 replies 17 participants last post by  jp2611
Hello...I am looking for a lift kit of at least 3" that has a SOFT ride. It is my daily driver and will do ZERO off roading. I used to have a 3" Rough Country spring/shock kit, but it was the harshest ride I have ever had. Bone-jarring and stiff-as-hell even on the highway. Again all I care about is to have the softest ride possible...thanks
I would have to agree. There are some 'softer' riding kits out there, but I don't believe any of them ride like stock. You would need to find a spring that is longer, but has the same spring rate as stock. Then you would need shocks that as soft as stock, so a stock replacement, or adjustable dialed down.
I would put a 2" spacer lift on it, and stock shocks. If you really need 3", add a 1" body lift. That'll get you to the mall and back just fine.
I'll bite...different perspective I think...I understand what you want (I think)..IMO ome SL lift 1.25 BL, and 33x12.50 15 duratracs...it make my TJ ride as well as my JK...well at least in my mind.....I think a lot of it is the tires actually more surface area and only about 26-28psi is SOFT!!!!
#8 ·
for a few years i ran a rancho 2.5 rockcrawler kit (short arms) with 33" tires. with shocks on the softest setting it was plush. that jeep swayed with more grace than beyonces arse. gosh i miss her...er, that jeep.
seriously, i found this a great compromise setup for street use and mild offroading
#13 ·
You will get zero complaints regarding ride quality of OME lifts. Pricey but well worth it. Combine OME coils with OME, Bilsteins, or adjustables Ranchos shocks and you will not be disappointed with the better than stock ride quality. Like others stated, check with DPG offroad. They specialize in OME lifts and will find the right combo for your application.
#18 ·
Call dirk at DPG Offroad. He can set you up with an OME lift that will fit your jeep as far as spring rate goes. And if OME isn't what you want (it is a bit pricey) he can help give you suggestions that may suit you better. Now he may try to sell you his more expensive lift, the "Ultimate TJ lift" (he talked me into it) but its because all of the steering and other upgrades that come with it will help your jeep perform as its supposed to on and offroad (if you choose to do there, which you will with a lift, it's impossible) :) he's a real good guy and he does sell a package with just springs and shocks that he will sell to you, he just doesn't like to sell it because he's a "do it once and do it right" kinda guys.
