When my
OAT is spilled onto the ground into a black catch pan it looks
green from the UV leak detection dye.
It looks
orange in the radiator.
It has looked
pink/
purple/
orange/
green/
box of crayons in the overflow reservoir from different angles and light.
This was 1 month after I bought it with 13.3k on it.
It had 1 Jeep dealer inspection service on it after it was sold to Autonation - Joe Arapahoe (Colorado) in July of 2017
Previous owner had it for exactly 1 year and 13k miles.
Coolant level when I received it.
After I added 1 qt of OAT - It was 1 quart low when i took ownership in February 2018.
Added leak detection dye 2-7-2020 (you can see in the overflow reservoir that it now has a orange/green tint to it)
Fast Forward thermostat change November 2022 - Existing OAT coolant with UV leak detection dye spilled into catch pan. (looks green on the black catch pan)
This is a brand new coolant overflow reservoir. The green tint is the UV leak detection dye.
I took these 2 photos at the same time. You cant see the dark green tint from the side.
The color of OAT is orange with factory added Purple dye. I am assuming the die wears off some over time.
When I flush the dye out it will probably stay purple.
It isn't HOAT mixed with OAT.
