Lug nut torque
2 reading
56K views 33 replies 24 participants last post by  Wharfrat
Quick question: What's the lug nut torque on JK wheels? I've searched and found values ranging from 100-125 ft-lbs. I'm doing a 5-tire rotation today at home. It'll be time consuming, but easy. The first I've done myself. The hardest part will be lifting the damn things.
It's 100 to 125. Pick a number and make them all that number. Mine are all set at 100. I check them a few miles after re doing them.
#7 ·
The JK manuals are fairly consistent at 100. Interestingly enough it is higher than for a TJ (same lug nuts) but my TJ manual says 85 to 110 foot pounds. I have been using 95 on both. I'll probably change to 100 on both.
#14 · (Edited)
now the $64,000 question...how accurate is your torq wrench? Be honest when was the last time it was calibrated. If a person forgets to set it back to 0-10ft/lbs before storing that messes them up. If you drop it that messes them up....Most want to be set back to 0 for storage but I have one that wants to be set at 10 ft/lbs for storage. The next question are you holding the torq wrench correctly when torqueing. I have seen many people grip and pull them improperly.
owns 2024 jeep wrangler rubicon
#27 ·
Agreed. Nobody calibrates them. Even at my employer that has gauge calibration our torque wrenches are sent out. Still a torque wrench that is off some is probably better than someones guess at the right tightness when it comes to lugs imo. I did watch a video somewhere on testing and calibrating your torque wrench with a luggage scale.
#18 ·
100 on the ground wheels and snug on the spare...
You guys think that 45 number for the spare is because of the stock pop metal carrier? Might pull those studs right thru if you go more?
#20 ·
Must be somebody I blocked...I can't see post 16....
Reactions: Old Dogger
#23 ·
I use torque bars when I do mine. Didn't know that the tire carrier was different, but haven't had a problem... yet.
#31 ·
Interesting, I just checked my 2014 FSM and 2014 Owner's Manual. Sure enough, 122 ft-lbs in the FSM and 100 ft-lbs in the Manual
But, I have found several places in the FSM that list different torque values in the specifications table versus the individual section of the instructions. Rear Sway bar bracket bolts for example; 52 ft-lbs in the table and 45 ft-lbs in the instructions.
#29 ·
It's important not to get any lube on the lug nut where it contacts the rim. On the cone.
